"show collections" button doesn't keep its status
dex
Post by dex »
I've noticed in v1.3.2 and updated to v1.3.6 under a virtual machine the "show collections" button doesn't keep it's activated status if I close and reopen a group or folder, or if I exit UE, whereas it does so and even after exiting and restarting UE under my regular Windows XP.
the show collections button doesn't persist since it makes sense to keep it checked on unchecked on per newsgroup/folder basis.
it is done in edit menu->properties->newsgroups, to show collections on opening for all groups just select "yes" in the "collections" combo for the topmost "default" entry.
