Can't search a subject with dots in it
Ender
Post by Ender »
Hi! I am trying to use Usenet Explorer for the first time. It took me an hour to get it going because I didn't know that the server name field is actually the address and I couldn't find a way to fix it once it was wrong.
I tried to search for the movie, "The Man From Earth" using the search service bar. I tried "man earth" That didn't find it. I tried "man and earth" That didn't find it. I read the documentation and learned that you have to use an ampersand.
I think that the search term, "man & earth" should find the movie but it doesn't. "man.from.earth" will find it. (I only knew to try that because I used another search service.)
If you cannot search for words separated by dots, it is a pretty big limitation since dots are used more often than spaces in the titles of binary posts.
Using "man&earth" finds what you want. Obviously remove the quotes and make sure there are no spaces between the words and ampersands. Inserting spaces will tell UE to search for:
Code: Select all
man & earth
will return anything with the words "man " and " earth" (includes spaces).
or use wildcard if order matters
man*earth
better read "search examples" at UE home page http://www.netwu.com/ue/help/patterns.htm
if you look for
man earth
you are like looking for the exact phrase.
there was a request to add an option to treat spaces as & when search pattern is non-quoted.
dengle
Post by dengle »
you can also use the ? character if you know the title, but aren't sure of the separating characters. i.e.:
man?from?earth
will match:
man from earth
man.from.earth
man_from_earth
etc
also, do not put spaces around the &. the search should be man&earth. otherwise, if I'm remembering correctly, it will be looking for
"man "
and
" earth"
without the quotes.
