View newsgroup list for one server?
aberly
Post by aberly »
Some software companies have their own NNTP servers with support groups just for their software. When I add one of these servers, I'd like to see a list of the newsgroups on the server, so I know what's available there. So I go to the Newsgroup List panel, right click on the server, and select Open. But this opens a list for all servers at once.
Is there a way to see a list of what's on a new server, so I can pick which groups I want to add?
in UE i didn't implement the option to filter by server, in newspro it was more detailed, if you need just to explore this way you can run newspro, in the quick filter you can filter newsgroups by server.
but the info is still there, for any newsgroup in UE in properties you can see the server, i just didn't proceed with the filter since i had to concentrate on other features with higher priority.
apart from running newspro you can just reset newsgroup list and download newsgroup list only from the server in question to see what newsgroups it has.
