Delete RAR after unrar w/ RAR files that has password?
Tenchi_Muyo
Post by Tenchi_Muyo »
would it still delete the RAR files after unrar if the RAR files has password set?
or will it bypass the delete task as it did not correctly unrar the files?
thanks,
if unrar wasn't successful (it failed to unrar because file is password protected) it won't delete the rar file or files, you'll see red question sign icon and error file is password protected or something like that.
then you can enter the password in advanced submenu, something like "Set unrar password", it will start unraring as soon as you've entered it, or you can doubleclick the entry and it will start winrar.
zlatan24
Re: Delete RAR after unrar w/ RAR files that has password?
Post by zlatan24 »
Tenchi_Muyo wrote:would it still delete the RAR files after unrar if the RAR files has password set?
thanks,
I have many tools on my PC. But once one of them was luckily used. It saved all my time and data. Moreover this application might help in any question in my humble opinion - fix a .rar file.
