Can't D/L all par2 files??? UE V2
MrEman
Post by MrEman »
I know it's a setting I've overlooked :oops:
But just can't seem to find it
I cue a collection of rar files including pars
UE D/L's all of the rar set and only 1 of the par's
Rar set is damaged and needs repair
I go back and re-cue all of the par set
UE D/L's 1 of the pars and deselects the remaining pars?
Using QuickPar for repair....
it should deselect when the rar set becomes repairable (you should see the "repairable" status in the status column), because it doesn't need more par2 files to repair it will cancel the rest.
if auto repair is checked it will start repair.
if you repair with quick par and quick par found less data blocks it would be some problem with quick par (but i think it shouldn't be the case), as to ue it found enough data blocks to perform the repair, so basically if quick par does scan the same well it should be able to repair with the par2 files which were downloaded by UE. more par2 files don't make repair faster, excessive repair data is not used at all.
in any case you can let UE to do the repair the result will be the same.
