Drag and Drop files into Unpack Window
ShaggyDragon
Post by ShaggyDragon »
Hi Alex,
Is it possible to add drag and drop facilities for the Unpack window? This way you can select multiple files and drag them in for unpacking/par checking?
I ask this because the Add Files option fails on multiple files when there are spaces in the file names.
Andy.
jonib
Post by jonib »
This would be something I would like too, It would be great to drag and drop a folder and have UE recursively verify, repair and possible unrar all.
jonib
jaapf
Post by jaapf »
That would be great indeed!
i think it would be more appropriate for v2.1 since i'm planning to consider adding some related options in a bunch.
but first i need to sort out the current feedback, probably that work will be finished tomorrow or the next day.
the feedback has been processed already, what has actually left is my own wish, i want to make cancelling tasks after par2 set is complete or repairable to be in accordance with the delete rules defined in save properties instead of cancel/delete bodies like it is now, sometimes i don't want to delete any article bodies.
