Suspended Save Queue
MageMaster
Post by MageMaster »
Any way I can tell why my save queue keeps getting suspended as I don't have a clue as to why.
I have 9.66 Gigs free and the database drive and 211 gigs free on the save drive.
MageMaster
in the task manager (tasks menu->task manager) check what is the topmost entry in the "save" pane.
it also should give error message box with reason why the save queue has been suspended.
to get the same error message not through the save queue doubleclick the entry to open the article body and save the attachment manually (context menu->save attachments).
if it is e.g. wrong path you can change the save folder in the task manager save pane (select desired entries->context menu->save path), but maybe other errors, e.g. directory name too long, file write error etc.
MageMaster
Since Then It has worked, All I did was rearrange the save queue.
