Unable to search alt.binaries.x264
intravenus
Post by intravenus »
For some reason i cant search this group anymore ( last 12 hours or so) all other groups are fine. Is the group still in the newsgroup list ?
yes, you are right, i mixed something after restoring from backup configuration.
i'm copying the fresh data files now, i'll restart the service when copying will be complete, then all will be ok.
swent
Post by swent »
I'm timing out on all groups, but just recently. It did work two hours ago.
"did not properly respond after a period of time"
please wait until the copy will be complete, maybe in 15-20 minutes, i need to copy around 190 days of retention across non-picture groups.
intravenus
thanks alex
