Filtering everything BUT a certain header.
jsfarmer
Post by jsfarmer »
Ok, lets say i am looking at a newsgroup, an MP3 group for example.
How do I filter out EVERYTHING BUT headers with mp3 in the description? I don't want to download yet, just filter the view.
This has got to be easy, I just can't find it.
Thanks,
Jeff
edit menu->message filter (or ctrl+s), 'subject' 'contains' 'mp3' and press 'extract'. to reset the filter edit menu->reset filter (alt+r) or the 'reset' button if the filter dialog is still there.
jsfarmer
And one more detail
Post by jsfarmer »
Thanks for the quick reply Alex.
Next item is:
If I want to keep two file types. say mp3 AND nfo, can I combine these in one filter or do I need to set up two? Do I need to add a boolean?
mp3 and nfo
Tha*Lunat!k
Post by Tha*Lunat!k »
The pipes symbol | acts as AND while you have checked the Boolean Wildmat option. Yours would be:
mp3|nfo
Extract
Erik
Post by Erik »
Tha*Lunat!k wrote:The pipes symbol | acts as AND while you have checked the Boolean Wildmat option. Yours would be:
mp3|nfo
Extract
| is OR to be exact :lol:
Tha*Lunat!k
Oh yeah :)
