Hello,
Why do I get incomplete posts when set to use SSL connections?
Downloading the same discussions, if i revert to port 119 no SSL, all is fine.
Any ideas?
Thank you
Incompletes when using SSL
Do you get any SSL connection errors in tasks menu->task manager, e.g. console tab?
The reason may be with your computer (firewall) or something en route, less likely the server.
If it is the case when you get them after reverting to 119 port frequently repair should be needed. Is it the case?
The reason is if some TCP packets are lost with no SSL - the newsreader still gets the data stream, with SSL data also checked for integrity, the first lost packet and you get the SSL connection error.
