Can't make usenet explorer default for nzbs
shak
Post by shak »
Hi !
I've just bought usenet explorer and i can't make it default program for nzbs
I had newsbin pro before and i removed it with youruninstaller . Ive tried to make it default through right clicking on nzbs and choosing ue.exe but it doesn't work
Also i went in edit -> properties -> general -> default newsreader and it doesn't work either . Not only that but now i can't uncheck the default newsreader checkbox in order to check it again
Is there a way to do it ?
Maybe with messing with the registry or something
shak
Re: Can't make usenet explorer default for nzbs
Post by shak »
I've managed to fix it using ccleaner , cleaning the registry and then using open nzb file with usenet explorer !
NoNo
Post by NoNo »
Glad you can help yourself! :mrgreen:
You could try to check edit menu->properties->search/import, nzb files, associate with nzb files, in Windows 7 run UE as administrator.
