How to *reread* all messages?
outside
Post by outside »
I want to read all messages of a newsgroup again, also the purged and deleted messages. All Tracking experired/deleted headers are switched off. reset headers or Reaset header range does not work. What do I do wrong?
Regards,
Outsider
Re: How to *reread* all messages?
Check what are settings in edit menu->properties->newsgroups "headers per server" and "retention" when you reset headers they should be redownloaded.
Resetting header range will still remember "deleted" headers, but purged headers will be redownloaded (for compact binary newsgroup type which is the default)
