UE.exe version 3.4 removed by Norton AV
Hubert
Post by Hubert »
Alex,
The new version 3.4 of UE was removed from my PC shortly after opening by Norton AV. Reason: "suspicious behavior". I remember having a problem like this once before. Could you please try and make a version that is not detected by Norton?
Regards, Hubert
Re: UE.exe version 3.4 removed by Norton AV
The behaviour of all versions is exactly the same which is downloading from news servers.
I cannot do anything about it, only if some random sequence in the compressed executable triggers false alarm I may change code a bit so it won't appear, but it didn't complain about a virus.
You need to add the program as an exception then or try to contact the norton support.
Hubert
Post by Hubert »
I have done just that now and all is OK. It must be like you say: a random sequence of bytes seen as a threat. Stupid AV-programs :lol:
Regards, Hubert
