Wierd problem with import folder not displaying correctly
dvd.collector
Post by dvd.collector »
I've just noticed an odd issue in UE v4.1. I've never experienced this issue before so I'm assuming its new to this version.
Basically, I perform a search using the search service, then press CTRL-D to import and download. This works and I briefly see the files in the import folder, but then they disappear from view. However the files are still there and ARE downloading but are only visible if I use the quick folder bar and view deleted headers (even though I have not deleted them).
The attached screenshot shows the files downloading and only visible when I choose to show deleted headers.
Let me know if you need any further information, or I've done something silly!! :shock:
dvd.collector
Re: Wierd problem with import folder not displaying correctl
Hi Alex,
the update does seem to fix the problem with the files not displaying, thanks!
Regarding the multiple par sets, yes UE does try to unrar after each par2 set is complete. However I worked out that was an issue and turned off auto unrar temporarily, but still experienced some other strange issues.
e.g. The first par2 set repaired fine and showed all files as complete. When UE then moved onto the second par2 set and repaired that... it seems that one file in the FIRST par2 set became corrupt again. I can't explain why this is - I can't even be sure this is what caused it... but even after showing one file was "complete", if I checked the first set again, one file showed corrupt the next time.
So I ran quickpar outside of UE and that seemed to work.
As to this particular set I tried - it appears to repair and unrar normally (I've deleted few parts to cause repair of two rar parts, otherwise it would be complete and would be no repair needed).
Do you mean some different download?
You didn't run quickpar repair concurrently or before UE repair, since it may mess things, say quickpar repairs, then UE repairs and the resulting files will be corrupted.
As to the wrong header state problem in short it has been now fixed.
