Search not complete after midnight to 1st oct 2013
Black76
Post by Black76 »
Hi. There are some problems with the search index after midnight today. Index is not updated in many groups - could you check?
jd
Re: Search not complete after midnight to 1st oct 2013
Post by jd »
I have the same problem. I can download things with NZB, but the search says "Not found".
swent
Post by swent »
It appears to be filtered, as both post title and author only results are incomplete.
dwhite32
Post by dwhite32 »
same here. I could not mind any tv shows which were aired last night in USA. Anyway to fix this??
A partition run out of space affecting about half of newsgroups, I had another computer with up to date results, I've added it now, so the search is now complete even as the affected instance is only catching up.
