Search problem - no response ?
grenouillle
Post by grenouillle »
Get no response of any search query...and no error message.
Does anyone have this problem too?
Re: Search problem - no response ?
It looks like working from here.
Is it still the same on your side? I'll send pm then.
grenouillle
Hi Alex,
now it is working again. After restarting UE twice
the search is running perfectly.
