Search Failed (4)
n2mdk
Search Failed (4)
Post by n2mdk »
Been getting this error since earlier this afternoon.
Sorry if the outage is due to a storm, not sure what date that's from.
tip32a
Re: Search Failed (4)
Post by tip32a »
I am having the same problem. Is this related to the news server I am using or is this internal to the program?
It is running now, I thought it has been started already, but it wasn't.
n2mdk
Post by n2mdk »
Thanks Alex all is good
tip32a wrote:I am having the same problem. Is this related to the news server I am using or is this internal to the program?
It's internal to the program.
