In de box properties [general] at the bottum you have two options.
One says too*manyllimitltimeout
Andd one. download*limit
I no there is something you can fill in so it works better but what is it.
Does anyone no what i mean??
newspro help needed [properties]
If you provider has download limit and the limit is reached - newspro catches the error message and suspends the server for some time, so for the feature to work - the error string should match to the boolean wildmat pattern and the suspend edit box should be set for non-null value (e.g. 30 min).
It is better to disalbe the warning check box to prevent annoying notifications when the server is suspended.
