NPDL manager v1.9 available
MikeStammer
Post by MikeStammer »
I will be posting v1.9 tonight.
Change log will be provided on the web site. This version includes a user recommended change for some additional columns to allow for better filtering. Should be updated by 6 PM CST
Mike Stammer
Jones
Post by Jones »
Thanks Mike
jdzn
What is v1.9?
Post by jdzn »
What is this program and what does it do? Are there any jobs for highly skilled usenet users (other than counterfeiting software :wink:
MikeStammer
Go to the site and read about it. Thats why its there.
http://mikestammer.com
Mike Stammer
MikeStammer
Urgent!
I found a bug in the last version that is pretty serious. I was using wrong column to move the files and it wasnt pretty!
Please download and reinstall the program to fix it. Sorry about that!
Mike Stammer
rulez
Post by rulez »
hi,
the current version produces an error while opening the SavedAttachments.txt.
error message box says "...unexpexted error... email author...".
what i did was starting npdl, file->open <path-to-SavedAttachments.txt>. operating system is an english winxpsp1 with european (german) regional (date&time, currency...) settings.
logfile 2004-01-03-NPDL Manager.log:
<21:35:20> SendError logged the following: Error in LoadFile(D:\tmp\check\newspro\database p\SavedAttachments.txt)
Cast from string "12.23.2003" to type 'Date' is not valid.
Stack traces: at NPDL.NPFile.LoadFile(String FileName, Boolean IgnoreNonExistent, DataTable dtIgnore)
at NPDL.frmMain.tbMain_ToolClick(Object sender, ToolClickEventArgs e)
at Microsoft.VisualBasic.CompilerServices.DateType.FromString(String Value, CultureInfo culture)
at Microsoft.VisualBasic.CompilerServices.DateType.FromString(String Value)
regards
rulez
Post by rulez »
would you provide an older version i could try?
thx!
MikeStammer
I do not have an older version. Sorry.
Mike Stammer
rulez
Post by rulez »
ok, thx for the reply!
is there anything i or you can do concerning the error?
greetings
MikeStammer
If you can email me your savedattachment.txt file i can see where it is exploding and most likely fix it. Just zip it up and shoot it to me. I should have it fixed early next week
Mike Stammer
MikeStammer
rulez your problem should be solved with v1.9.1 that i will be posting tonight. please test it out and let me know. thanks!
Mike Stammer
