Newsfeeds Unlimited account
Servers:
news.Easynews.com
Max Task: 6
Retries: 3
Connect dealy: 0
Enabled Priority: 1 S
Msg-id direct / Supress get hdrs: unchecked
Unlimited.newsfeeds.com
Max Task: 3
Retries: 3
Connect dealy: 0
Enabled Priority: 128 S
*.newsfeeds.com (no subnet)
Max Task: 3
Retries: 3
Connect dealy: 0
Enabled Priority: 70 S
Msg-id direct / Supress get hdrs: both checked
Tasks:
Total 20
Easy Task
12
3
10
Hard task:
20
8
3
Gerneral:
standard checkbox options checked and unchecked
Ignore Priorites for maxed servers: checked
Exceeding Download Limit (boolean wildmat match):
download*limit|430*article|400*Many|502*Many|423*Article
Suspend Server for:
10min
Minimize disk accesses on start:
checked
By doing this it allows me to have more then 30 large size groups in one database, auto get header every 90min / watch download filters. without crash for the pass 2 months, while keeping the Database size very small since it only has 2 server headers, makes get new header time / speed blazing fast. if anything not in on the unlmited server it'll try the other servers if not found pause server 10min before going to easynews. every month i have to log on easynews web to use up more then 4 gig of left over credit, might cancel it if i can find a better Header server.
Now to make it better. well there really isn't much more todo with this setup since it wont really matter but i just thought maybe if alex can make a different keyword box for pause per server "Msg-id direct" for 10min then i can still pause 3hours for limit exceed servers. but it really doesn't matter pausing the server 10min or 3hours when it's limit reached or a file isn't found
