"Search failed (10)"
Black76
Post by Black76 »
I am getting "Search failed (10)" since yeasterday - anyone else?
Happy Holidays out there.
dxcarnadi
Re: "Search failed (10)"
Post by dxcarnadi »
Me too ...
server went down likely due to overheating, in the meantime i restarted the search service in backup configuration; also a hard drive on this server is due to be replaced and all other hardware issues addressed.
later update: the hardware upgrade has been completed with better results than expected.
