Search result shows incorrect size
tomhock
Post by tomhock »
When I search for large rar sets, the results typically show a collapsed post with its total size to the left. However, recently the "total" size figure has been misleading. If I expand the entry, the actual size of the entire post size may be much larger. In some cases, I can't even determine what the "total" figure represents because it seems to have nothing to do with the sizes ofthe major divisions within the post.
This is a problem. A minute ago, I thought I was queing up an 4GB post which turned out to be an 11GB post. I'm relatively sure that this is something new. I first noticed it a few weeks ago, and I am almost certain that the top number used to always be the sum of all the parts below it.
Re: Search result shows incorrect size
I'll check it out, it is the collection entry, it should be the sum, it is something trivial to fix caused by adding sets in search.
Collection is virtual entry, it doesn't affect imported results. I will fix it and recompile the code.
tomhock
Post by tomhock »
Thanks Alex. I knew that was not what I had seen in the past.
I'm in the process of upgrading the search service hardware, after it will require less attention I'll look at the code, won't take long.
Mierzoet
Post by Mierzoet »
Is this issue still ongoing? As I have noticed it as well.
wrong size for collection in search.jpg (37.34 KiB) Viewed 15078 times
I'll try to check and recompile shortly.
Upgrade takes longer than expected.
I fixed it here, I'll try to publish it tomorrow.
check the latest version, should work now.
