Search failed (8)
worrall
Search failed (8)
Post by worrall »
Alex --
Search is failing once again. Can you let us know if the service is down, or, you have changed ports, or changed search service IP addresses again?
Thank You
Re: Search failed (8)
One ip address changed recently by ISP, but it was November, 5, I'll pm you.
worrall
Post by worrall »
Alex --
Thanks - Had to whitelist the new IP address. All working again.
Joe
