too many results error
fellowda
Post by fellowda »
All of a sudden I get a "too many results some results will not be shown" message on every search even when there is only one result.
Re: too many results error
Is it the same now?
Can you give me or pm me such search?
It may be the case with complex searches which take too much time.
It was server side issue, after I updated the server yesterday simultaneously with the latest release.
I added code to make searches faster in some cases, when it is triggered the search function exits earlier. The too many results variable wasn't assigned, so it could be anything without affecting the search results.
So it was a false warning.
It is fixed now.
