Passwords
Herbie
Passwords
Post by Herbie »
Hi, alex
Would it be possible tu use the passwordmask as SABNZB and Newsleecher uses
Downlaodname{{Passord}}
So if we put this in the filerequest after a sucessfull search the PW ist automatic connected with the download.
Thankyou
Herbie
Re: Passwords
I could add a dialog with the password list which is opened from the unpack menu.
Can you give me exhausting examples what is the use of this feature? In your case is it a steady list or the passwords are constantly changing?
I mean the user will always will type the file name or it should be also somehow derived from the subject to add an entry?
