Search results missing or hidding big file
NoNo
Post by NoNo »
Hi there,
I'm having some trouble with the search results when the poster use big files.
It doesn't show on UE but it does appear on NZBIndex.nl.
If I create and import an NZB file from NZBIndex, the file still doesn't appear and it just don't download.
The same NZB file on my Synology download station does work.
I have that perfect example, when using "macross&plus&movie&1080&mgrt" as a search expression,
there should a big .mkv file that is 8.66GB like in the NZBIndex result.
Re: Search results missing or hidding big file
I pm-ed you the link to the solution. It will be included into the next release. The way of posting of 9gb file as one partial is extremely abnormal.
Try to import the nzb there. Don't use previous versions afterwards, since I had to add something to the partial save database format, which will be not recognized and will crash previous versions (only on those headers).
I'll update search service later.
Please confirm you got it.
Search service is being updated, after few hours all will be there.
NoNo
Post by NoNo »
Sorry, was kinda sick.
Didn't get the solution, but it's ok since you're working on it.
I'll just wait for the next release :D
I'll upload it again later, likely tomorrow, when I finish with something else, I've updated the search service already.
I've sent you another link, let me know when you got it.
NoNo
Post by NoNo »
I got the link, thanks.
Apart the fact that the collection size says > 4.48 GB or > 4.33 GB,
I was able to successfully download one 9.57 GB file through the search engine
and one other large 9.27 GB file through importing results from NZBIndex.nl website.
That guy/bot is crazy :shock:
Seems like it's working. :D
When marked for download it adds the download size/calculates remaining time correctly.
In the import group in principle it could show the exact size in the header list, just those posts are so rare I'm not sure whether to change it.
And in the version I sent to you it doesn't work, but in the next release when you press F4 on the header (to show header propertiles) - it will show the actual size except for the case of compact binary group with parts of the partial not loaded, so it will always work for the import group.
