Move license and all settings to new computer
Black76
Post by Black76 »
I am going to move to a new computer.
How do I move my license and all settings from Usenet Explorer to the new one?
Thanks in advance.
Black76
Re: Move license and all settings to new computer
Post by Black76 »
Anyone please?
You can just copy the UE database directory or only the settings subdirectory, it contains everything to run the program.
If you already created another database folder it is possible to switch database folder in edit menu->properties->general->database, database folder, change, you should point to the folder which will contain the settings subdirectory.
e.g. if the Settings subfolder is in "d:\Ue Db\Settings" point it to "d:\Ue Db"
Black76
Post by Black76 »
Thanks I will try that :)
And the license will work on my new computer and will be deactivated on the old one?
(The old one here will recycled after HD is removed)
It is single user license, so you can use it on both computers.
There is no authentication server, no activation/deactivation.
