More and more non standard NZB files are appearing on usenet indexers that require nzbget to function.
Usenetexplorer cannot handle these and gives a lot of garbage, as is warned for in the post when not using nzbget, so it is intentional.
Kindly inspect attached (2) nzb files and add support for this exotic format.
No standard NZB files, download error
- packb.rar
- Non standard nzb files that require nzbget to work.
- (124.9 KiB) Downloaded 1127 times
Re: No standard NZB files, download error
I'll check it out, this is the kind of posts which were dealt already in the past, probably a way they malform them little changed.
Also read my pm.
Also read my pm.
Suggestion for a workaround...
d/l all the rar parts (I assume you now have hundreds of files all approx 750KB each)
separately d/l the par2 file, and rename this to something.par2
run this par2 (using QuickPar), then Add, select all, Open
QuickPar will "rejoin" these small files into a fewer rar files
It was handled already, I just need to compile a release.
