Search Service: What is the DNS Name and Ports Used
worrall
Post by worrall »
Alex --
Would you let me know the DNS name which UE connects to for searching and the destination port(s) used? Setting up a new firewall. Thanks.
Re: Search Service: What is the DNS Name and Ports Used
see pm, ports are the second column.
acrophile
Post by acrophile »
may I have this info too please?
pm
