Search with the latest version
chbron
Post by chbron »
After the latest upgrade I cannot get older results. It worked ok yesterday. Thanks for looking into it.
Re: Search with the latest version
I've added a note on the forum list page.
With v5.3 which was released today there is a slight database change on the server side and older code cannot work with it, so reverting to the older database format would require unraring and copying a lot of backup files.
I tested the code sufficiently, but out of caution I first run it with 1000 day retention, just now I have increased the retention to 1400 days and maybe later today I will run it with the full growing retention which is currently around 3700 days.
So a bit later it will show older results as well.
It is now running with the full retention.
