Search Server ... Search failed (8) .. (System 10054)?
dxcarnadi
Post by dxcarnadi »
Hello
see picture
Search Percy Faith ... Search failed (8) .. (System 10054)
What do they mean?
Thank you
2019-09-04 12_31_03-Usenet Explorer - search Percy Faith.png (30.23 KiB) Viewed 9274 times
Re: Search Server ... Search failed (8) .. (System 10054)?
There was a problem on one server, it was fixed shortly afterwards.
