Search Server Down?
worrall
Search Server Down?
Post by worrall »
Looks like the search server is down.
Re: Search Server Down?
A router has been replaced and a server IP address changed, so it was down for a short time, but it should be running now.
When you posted it was supposed to be running, it happened more than 24 hours ago.
If it is still appears to be down you may also try edit menu->properties->search, reset configuration.
worrall
Post by worrall »
Alex --
No change after reset. Could this be our firewall rules? We currently allow ports TCP/2020 through 2042 to both ueservice.hopto.org and ueservice2.hopto.org. Is that still correct or has this changed?
ueservice2.hopto.org ip address changed, ports are the same.
maybe try to update ueservice2.hopto.org
