Search failed (8) .. Select timeout error.
dxcarnadi
Post by dxcarnadi »
Hello
I get an error message: Search failed (8) .. Select timeout error.
What does it mean?
Thank you
telex
Re: Search failed (8) .. Select timeout error.
Post by telex »
here the same ,no answer from search
NoNo
Post by NoNo »
I got no answer from search too.
One server went down while I was on 10 hour flight, I fixed it mostly so the search works, but the server is still down, it should be up shortly.
Nono: if the search doesn't work, try to reset search configuration in properties, it was fixed like at least 6 hours ago.
NoNo
Post by NoNo »
It's working now, thanks :D
The other server is also up now.
