Search service is down
worrall
Post by worrall »
UE is returning the following error for any attempted search:
"Search failed on all servers (configuration ok)
Cannot find server or DNS error
Tested the search service dynamic DNS records and they are not resolving.
Please fix.
robbie47
Re: Search service is down
Post by robbie47 »
Same today. Still no fix......Alex are you travelling?
worrall wrote:UE is returning the following error for any attempted search:
Please fix.
worrall
Post by worrall »
Search is still down. Alex?
TechTeacher314
Post by TechTeacher314 »
"UE is returning the following error for any attempted search:
Tested the search service dynamic DNS records and they are not resolving."
Still down. Any word on what's going on?
Jim
stevendm
Post by stevendm »
Still down. Please fix.
Is it working currently?
What is the error? The search appears to be running here. Did you try to reset the search configuration in edit menu->properties->search/import?
One server was down on Friday I think, but I adjusted the configuration and it was running on one server for about 12 hours.
thekays
Post by thekays »
Search service is still down. I reset the search configuration.. restared UE and received:
Search service configuration has been update
(Triggered after...)
Entered a search, and after a long wait, received:
Search Failed (20)
A connection attempt failed because the connected party
did not properly respond after a period of time
it should work now, the internet on one location went down, i switched to another server.
thekays
Post by thekays »
That got it! It's working now.
