cannot retrieve any information
fellowda
Post by fellowda »
As soon as I select a server I get a message "cannot connect to server or DNS error" then nothing so I cannot use. I have beenusing UE for years and never had this problem. Haven't been able to connect to anything for several weeks.
Grandpakewl
Re: cannot retrieve any information
Post by Grandpakewl »
I got back in business this morning after having this for days.
