Usenet Explorer
Download
New users please check out selected topics.
When upgrading or switching from trial to registered version - your settings/database will remain intact, you only need to replace the executable.
v7+ is capable of running 7z command line to unpack 7z or zip files automatically, see asynchronous unpack Setup
To create par2 files when posting binaries the program needs the updated Par2CmdLine utility, you can download it here.
The 64 bit version doesn't have the inherent memory allocation limit of a 32 bit process, so it allows to load more headers simultaneously.
Selected releases for registered users:
Latest: v7.6.2 (64/32)    Up-to-date: v5.9.9.9 (64/32)
Download older versions
