Bug with visible window
kfaessen
Post by kfaessen »
i've found a very annoying bug with the NZB import files. NZB leecher automaticly opens the NZB files with the default program (in my case newspro). If i've not focussed on newspro and the NZB file is thrown to newspro and i open the window of newspro the save to window is behind newspro. This is very annoying because newspro doesn't respond to anything anymore. I've also opened the task manager (not sure if this has to do something with the problem). The only solution i've found untill now is rightclick on the systemtray icon and exit newspro and restart it or else you'll need to fix the database.
If this problem is already solved for 3.80 then ignore it.
Greetz,
Kelly
what window are you talking about, the save attachments window? can you send me a screenshot of the window?
