Is it possible to scan all 80.000 - 100.000 newsgroups for a selected file with newspro??
For example : searching for a file with the name "S_L.rar" ?
scan all groups
most newsgroups are garbage, there is no 100000 useful newsgroups
there is a site http://alt.binaries.nl you can look there, then enter a pattern in a search xpat group (see homepage) and get what you need.
it is no probem to add thousands of newsgroups in a search group but it will be slow, I don't know how much time will take 1000 xpat requests, if you have a number of good servers you'll see results faster proportionally to the number of servers.
if you just download newsgroup list from all servers, then you'll have all useful newsgroups in the list, no sense for a server to hide a newsgroup since then noone would know about it except for small number of users and it will be hosted only on that server since other servers won't know about it too.
- Contact:
You could also try out Binnews.com . I checked their global database and they have those two groups listed, so if you searched for something and it were posted in one of those groups you'd get a match. They will add a group for you if it's not already covered (though all should be covered).
