Exceeded download limit :(
Merlink
Post by Merlink »
Hello
i have a little problem, i tryed to setup the download exceeded server-stop, but it doesn't worked...
My server sends:
Error 502 No Permission: exceeded download limit
So i used the same string to make npro disable the server once received such Error Message...i tryed also quoting the ":" into "\:" and making some ".*" at the end of the line, but it seems to ignore me :(
what can i do?
Ah...is there a way to get some statistics like "how many MB did i download in a month?" I reset the download counter every 24 hours...
Tnx A Lot ^_^
...uh ah... i'm not english...so don't bother my for what i wrote ^_^
See ya
John Asher
the default value in properties->general, exceeding download limit:
download*limit
is adequate, so no need to add anything more, the only thing set non-zero value in the 'suspend server' edit field to the right, set it e.g. for 30 min.
also better uncheck the warning message box otherwise every 30 min (if you set suspend to 30) it will be shown.
Merlink
Post by Merlink »
