Is there a difference between the full version and the trial
MikeStammer
Post by MikeStammer »
or is the trial just time limited? So far so good with this program. Its pretty bulletproof!
differences are cosmetic, this is the same code (registered also would work as trial), in the trial automation and scheduler are disabled (propertis->watch and properties->scheduler).
