Log files
AkAzAm
Log files
Post by AkAzAm »
Does anyone knows if there is a way to log the posts that were made by newspro, so I can check if mt postings are bieng done ok. (not the error window, that works fine).
Greetings,
R-win
there is post menu->posted messages, a view that contains all posted messages, if something didn't appear on the server properly you can repost it with the same settings, it is not a problem.
AkAzAm
Post by AkAzAm »
Yep, i know that one..
But if I do a repost (i.e change the subject line to Repost......) then the original is gone. So there is no way to see the first posting.
