Is is possible to run multi copies of newspro same time
wah
Post by wah »
Is is possible and how?
I remember that this had been discussed sometimes ago but cn't find the thread.
Thank in advance.
http://www.usenetopia.com, running multiple instances, it doesn't work in the trial, not just because it is trial but because it didn't fit. the work is going on to render the option unnecessary (although it will stay there anyway).
edfreeman
Post by edfreeman »
One potential problem is the max number of connections per server. This would only be a problem if the multiple instances were allowed to run tasks to the same server at the same time. Be sure the number of allowable tasks on each server for each instance doesn't exceed the max tasks from the server as a total.
