NewsPro not get all headers
Ballshamin
Post by Ballshamin »
Hello again... :wink:
At last months, I can't recover all headers posted for some users.
I have to use BNR2 to can complete a file, using XHDR (not XOVER), because the headers are in the server, but NewsPro not show them. Although I rescan the newsgroup several times, they don't appears.
The same occur with X-News that use XOVER to recover headers.
There is some option to recover this headers?
Thanks again for your help...
maybe you deleted the headers? - i think xhdr and xover should use the same data source (xhdr just takes only a single field), so the results should be the same.
edit menu->show deleted headers will show such headers (if purging is on you need to disable it first and perform rescan before this), then you select the headers you want to undelete and invoke 'undelete headers' from the context menu.
Ballshamin
Hello,
No, I don't remove headers.
The same problem occur to others users using others newsreader.
NewsPro and X-News can't recover all headers, however BNR2 can it (using XHDR).
Thank you for your help...
