download incomplete files with a [color=red]?[/color]
hdvr
Post by hdvr »
I know how to download incomplete files, but I have another problem now. When I did a XPAT-search I found all the files complete, but when I started downloading some segments are missing, so newspro downloads only those segements and puts a ? at the green box.
Is there any way to save the already downloaded segments?
I hope for some help, otherwise I'm downloading a full dvd for nothing :wink:
just select the files and invoke 'save' newspro asks confirmation but eventually saves them.
it only makes sense if there is par2 recovery and the complete parts are not enough to restore the rest.
also check console or task manager, the error pane after the article pane why the parts are missing, also read this topic:
http://www.netwu.com/newspro/phpBB2/viewtopic.php?t=360
sometimes when you try again all works, might be some temporary server problem.
hdvr
Post by hdvr »
thanks for your quick answer. I'll try it when I'm at home :wink:
