Improvement: Add password to searched and queued downloads
jd
Post by jd »
Hello,
using the built in search workflow for encrypted and password protected posts works like this.
1. Search
2. ALT+D to download.
3. Wait for it to show up in task manager, right click -> enter password for unpacking.
4. If you download many of these, it's confusing because you either wait for the downloads to show up in task manager or manually set the first PAR/RAR of a set high so it's possible to set the password.
Maybe it's possible to make this easier?
1. Search
2. ALT+D+? some other command - pop up for password for this download?
Would save a lot of time.
Re: Improvement: Add password to searched and queued downloa
The password can be added to the name of the custom collection, it is done automatically e.g. when importing nzb files which contain passwords.
But if it goes directly to download, maybe we could add this without a collection, I'll check it out.
jd
Post by jd »
I think I'm an idiot. This already works in UE.
Search for stuff -> Press ALT+D
-> Stuff get's queued. It's highlighted in the queue. Then I can simply right click and add the password.
