Newsgroups (Help, Newb) :(
Bob123
Post by Bob123 »
I'm new to the Usenet thing :shock: . I have giganews as my server and have set it up. But when I go to get the newsgroup list, nothing pops up. I forwarded all the proper ports and whatnot, so I'm confused.
In Workspace, Servers the little comp is Green with what looks like a lock (I assume that's the SSL). On Newsgroups, it's black with a red dot to the bottom right.
Help would be appreciated. :) :)
maybe you need to set port, check on their site which port they use for ssl (if you use ssl).
you can set it through workspace right click context menu ->advanced->rename to append the port number to the server name after colon or maybe easier to type the port directly in edit menu->properties->servers, the "port" edit box.
you can also see the error, in the task manager the red question sign pane, but if you try to connect to non-ssl server/port with ssl option checked you get timeout error, since non-ssl server writes first, with ssl newsreader it is newsreader.
