For a few days now i'm getting this error when i'm trying to download an attachment from an newsgroup. I have tried everything. Even starting with an new database. or another computer.
I'm using new-service.com as profecial newsserver and from that I'm getting the Error 220 0. I dont't have this problem with the newsserver from my ISP.
Can anybody say what is going on here.
m.v.g.
Ruud
news provider problem
i've sent them an email, they gave me test account credentials and i checked it, all is ok, very fast server and all appears to be working, i downloaded a few messages in alt.binaries.sounds.music.classical - no problem at all.
he told me they also fixed the issue with downlading by message-id so message-id direct, xpat etc. should work with no problems there. it is the same service that maintains free search http://alt.binaries.nl
if you have specific info about newsgroups+posts, i could check it here or you can contact the newsserver support (i could check it so you'll be sure it is a server problem not something on your computer).
